Zum Hauptinhalt wechseln
Toshiba Satellite P55W-C5200X RAM Replacement
Was du brauchst
  1. Toshiba Satellite P55W-C5200X RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite P55W-C5200X RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 2, Bild 1 von 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P55W-C5200X RAM Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Toshiba Satellite P55W-C5200X RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Hadi Termos
241 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G2
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 805
