Einleitung
Use this guide to remove the Toshiba Satellite P55t-A5116 Fan CPU cooler.
Was du brauchst
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Gently pry off the bottom case with the plastic opening tools.
Find the seam between the back case and the rest of the laptop casing.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using a PH0 screwdriver, remove 2 (5.7mm) screws.
Using a PH0 screwdriver, remove 4 (3.68mm) screws.
3 weitere Personen haben diese Anleitung absolviert.
