Einleitung
Use this guide to remove the Toshiba Satellite P55t-A5116 Keyboard.
Was du brauchst
Einführungsvideo
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Gently pry off the bottom case with the plastic opening tools.
Find the seam between the back case and the rest of the laptop casing.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using the #PH0 screw head, remove 2 (5.7 mm) screws.
Remove metal plate.
Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
Gently pull up the power jack. Follow the cord until you reach the connector.
Unplug the 4 pin connector and remove from laptop
Using a PH0 screwdriver, remove 2 (5.7mm) screws.
Using a PH0 screwdriver, remove 4 (3.68mm) screws.
Pull out the latches on either side.
The RAM should pop up.
Remove the RAM.
Repeat for the other side.
Use a plastic opening tool to gently lift the black ribbon tab and unplug the ribbon cable.
Remove the ribbon.
Lightly pull up the USB Port from the metal supports and take out of the laptop.
Remove LAN port/ ethernet port. Lift up the ethernet port.
Unplug the 8 pin connector.
Using the PH0 screw head, remove 1 (3.8mm) screw.
Separate the wireless adapter chip from the motherboard.
Using a plastic opening tool, lift up the black ribbon tab and the smaller orange tab which are connected to the keyboard underneath.
Unplug the ribbons.
Using the PH0 screw head, remove 2 (5.7mm) screws.
Using the PH0 screw head, remove 1 (4.2mm) screw.
Using a plastic opening tool, remove the CP Tab that was plugged into the touchpad.
Lift up the mother board and gently flip it over to sit upside down next to the laptop.
Using the #J000 screw head, remove 20 (1.67mm) small screws.
Using the #J000 screw head, remove 4 (2.44mm) wide flathead screws.
Using the #J000 screw head, remove 1 (4.1mm) screw.
Gently lift up the metal frame from the laptop.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
This is by far the most informative instructions I have ever come upon. Not only does it explain the keyboard removal (which was my issue), but also explains the removal of pretty much every component that might need to be replaced excluding the screen. Thumbs up! I will definitely refer all my friends all colleagues to iFixit. Again Thumbs up!
Make certain you view the comment at Step 3, it’s hidden unless you click on it. May save you time…
