Zum Hauptinhalt wechseln
Toshiba Satellite P55t-A5116 RAM Replacement
Was du brauchst
  1. Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: Schritt 1, Bild 1 von 2 Toshiba Satellite P55t-A5116 RAM  Replacement, Back Casing: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 2, Bild 2 von 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 3, Bild 3 von 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: Schritt 4, Bild 1 von 3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: Schritt 4, Bild 2 von 3 Toshiba Satellite P55t-A5116 RAM  Replacement, RAM: Schritt 4, Bild 3 von 3
    • Locate the RAM cover on the back of the Laptop.
    • Using the #PH0 screw head, remove 1 (5.7mm) screw.
    • Use the plastic opening tool to remove the RAM cover.
  5. Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite P55t-A5116 RAM  Replacement: Schritt 5, Bild 3 von 3
    • Pull out the latches on either side.
    • The RAM should pop up.
    • Remove the RAM.
    • Repeat for other side.
Abschluss
Ein Kommentar
I’m confused… it only seems like Step 4 and Step 5 are necessary. Does the battery need to be removed before replacing the RAM? If that’s why Steps 1-3 are there, there’s a lot of steps/information missing. It just goes from “take off the bottom case” to “remove the RAM cover of intact laptop”.
Douggy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 569
