Zum Hauptinhalt wechseln
Toshiba Satellite P855-S5312 Fan Replacement
Was du brauchst
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: Schritt 2, Bild 1 von 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: Schritt 2, Bild 2 von 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: Schritt 2, Bild 3 von 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: Schritt 3, Bild 1 von 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: Schritt 3, Bild 2 von 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: Schritt 3, Bild 3 von 3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite P855-S5312 Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite P855-S5312 Fan Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite P855-S5312 Fan Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite P855-S5312 Fan Replacement: Schritt 6, Bild 2 von 2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite P855-S5312 Fan Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite P855-S5312 Fan Replacement: Schritt 7, Bild 3 von 3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
Abschluss
Dalton
215 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S10-G2, Thompson Fall 2017 Mitglied von USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 561
