Zum Hauptinhalt wechseln
Einleitung
The bottom cover will need to be removed in order to access replaceable parts inside of the laptop. This is a simple process that requires the removal of ten easily removed screws in addition to the battery removal.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two 7 mm Phillips #1 screws that hold the battery in place.
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Pull the battery from laptop. Pull the battery from laptop. Pull the battery from laptop.
    • Pull the battery from laptop.
  3. Remove the ten 7 mm Phillips #1 screws that secure the back cover. Remove the ten 7 mm Phillips #1 screws that secure the back cover.
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
Abschluss
USF Tampa, Team 2-1, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 97
