Zum Hauptinhalt wechseln
Toshiba Satellite S55t-A5389 Keyboard Replacement
Was du brauchst
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite S55t-A5389 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
William Mazanec
1.350 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S5-G6, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 592
