Zum Hauptinhalt wechseln
Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement
Was du brauchst
  1. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: Schritt 4, Bild 1 von 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 5, Bild 2 von 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement: Schritt 6, Bild 2 von 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: Schritt 7, Bild 1 von 2 Toshiba Satellite S55t-C5225 Optical Disk Drive Replacement, Optical Disk Drive: Schritt 7, Bild 2 von 2
    • Carefully slide the optical disk drive to the right to remove from the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G5, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G5
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 348
