Einleitung
If your Toshiba S55t-C5225 can no longer read CD’s/DVD’s or will not open then your optical disk drive is most likely not operational and needs to be replaced. The following steps are a guide to help the user in replacing the optical disk drive.
Was du brauchst
Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
Wedge the tip of a plastic opening tool between the back cover and metal frame.
Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
Repeat these steps around the laptop to release all retaining tabs.
Carefully slide the optical disk drive to the right to remove from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
