Zum Hauptinhalt wechseln
Toshiba Satellite S55t-C5225 Speakers Replacement
Was du brauchst
  1. Toshiba Satellite S55t-C5225 Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 3, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: Schritt 4, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 5, Bild 2 von 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 6, Bild 2 von 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Speakers Replacement, Speakers: Schritt 7, Bild 1 von 1
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 9, Bild 2 von 2
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 10, Bild 1 von 2 Toshiba Satellite S55t-C5225 Speakers Replacement: Schritt 10, Bild 2 von 2
    • Lift speakers up from their mounted position to remove.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ali Mortada
226 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 Mitglied von UMass Dartmouth, Team S1-G5, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G5
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 41
Insgesamt: 955
