Einleitung
If your Toshiba Satellite S55t-C5225 sound quality is poor or if they are no longer operational then the battery most likely needs to be replaced. Operational speakers provide crisp sound quality without interruption. Follow this quick and easy guide for replacement.
Was du brauchst
Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
Wedge the tip of a plastic opening tool between the back cover and metal frame.
Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
Repeat these steps around the laptop to release all retaining tabs.
Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
Pull the ribbon wire out from plastic clamp.
Follow the black wire that connects the speakers to the motherboard.
Pull the wire out from its socket to disconnect the speakers from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
