Einleitung
This guide will be very useful if you are facing problems with turning on your device.
If you are having trouble turning on your Toshiba Satellite T135D-S1324 you might want to replace the battery. By replacing the main source of energy you should find that your laptop will light up and you should be able to get back to work in a matter of minutes.
Pull back the claps to release the battery.
When the battery is unlocked, pull back the battery to completely remove it.
