Einleitung
The battery on the Satellite is relatively small and after a year or so it may no longer hold a full charge. Replacing the battery will allow you to retain the full functional life.
  1. Make sure that the laptop is off and unplugged.
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Rotate the laptop 180 degrees so that the battery is near you.
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Brandon Kirklen
Mitglied seit 11.01.2013
269 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 7-8, Maness Winter 2013 Mitglied von Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 395
