Zum Hauptinhalt wechseln
Toshiba Satellite U405D-S2902 Display Replacement
Was du brauchst
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: Schritt 1, Bild 1 von 1
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 2, Bild 2 von 2
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: Schritt 4, Bild 1 von 3 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 4, Bild 2 von 3 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 4, Bild 3 von 3
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 5, Bild 2 von 2
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 6, Bild 2 von 2
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: Schritt 7, Bild 1 von 2 Toshiba Satellite U405D-S2902 Display Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 7-8, Maness Winter 2013 Mitglied von Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 681
