Was du brauchst
Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
Carefully pull the top away from the back.
Remove the lower lighting power supply.
Remove the signal light power supply and data cable.
Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
Carefully remove the screen from the side brackets.
Remove the LCD ribbon connector from the display.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
