Zum Hauptinhalt wechseln
Einleitung
The bulb of a projector is only rated for a certain amount of hours, so when it reaches the end of its life the image will become fuzzy and eventually die out. This guide will show how to replace the bulb on this projector.
Ersatzteile
  1. Remove the two screws from the bottom plate as shown. Remove the two screws from the bottom plate as shown.
    • Remove the two screws from the bottom plate as shown.
  2. Remove the two screws on the bulb housing.
    • Remove the two screws on the bulb housing.
  3. Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out. Replace the bulb with an equivalent one.
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
    • Replace the bulb with an equivalent one.
Abschluss
Bryan Underwood
697 Reputation
5 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 143
