Einleitung
In the rare case of a power surge, if the device is not plugged into a surge protecting outlet, the fuse will blow out and need to be replaced. This guide will show how to tear the whole projector down to get the fuse and replace it.
Was du brauchst
Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
Remove cables from the power supply board.
Remove the screws located around the board to un-mount it.
Locate the fuse near where the power adapter was.
De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
