Zum Hauptinhalt wechseln
Toshiba TECRA R940 Back Panel Replacement
Was du brauchst
  1. Toshiba TECRA R940 Back Panel Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba TECRA R940 Back Panel Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Back Panel Replacement: Schritt 2, Bild 1 von 2 Toshiba TECRA R940 Back Panel Replacement: Schritt 2, Bild 2 von 2
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 2 Toshiba TECRA R940 Back Panel Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Back Panel Replacement: Schritt 4, Bild 1 von 2 Toshiba TECRA R940 Back Panel Replacement: Schritt 4, Bild 2 von 2
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Back Panel Replacement: Schritt 5, Bild 1 von 1
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Back Panel Replacement: Schritt 6, Bild 1 von 2 Toshiba TECRA R940 Back Panel Replacement: Schritt 6, Bild 2 von 2
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Back Panel Replacement: Schritt 7, Bild 1 von 2 Toshiba TECRA R940 Back Panel Replacement: Schritt 7, Bild 2 von 2
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 990
