Zum Hauptinhalt wechseln
Toshiba TECRA R940 Hard Drive Replacement
Was du brauchst
  1. Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
    • The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
  2. Toshiba TECRA R940 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Toshiba TECRA R940 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  3. Toshiba TECRA R940 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Toshiba TECRA R940 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
Abschluss
Ein Kommentar
I cannot lift up the “back cover” (step 1). I’ve twirled the screw left for minutes and tried to lift up the panel using a small flathead screwdriver and it will not lift up. HELP!
Remy Secor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 1,034
