Zum Hauptinhalt wechseln
Toshiba TECRA R940 Keyboard Replacement
Was du brauchst
  1. Toshiba TECRA R940 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Keyboard Replacement: Schritt 2, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Keyboard Replacement, Back Panel: Schritt 3, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Keyboard Replacement: Schritt 4, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Keyboard Replacement: Schritt 6, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Keyboard Replacement: Schritt 7, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
  8. Toshiba TECRA R940 Keyboard Replacement, Optical Drive: Schritt 8, Bild 1 von 1
    • Remove two 2.5 mm screws from the side of the optical drive using a Phillips #0 screwdriver.
  9. Toshiba TECRA R940 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Lift up the bracket covering the connector.
    • This bracket should not be fully removed from the optical drive.
  10. Toshiba TECRA R940 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Gently remove the SATA connector from the port.
  11. Toshiba TECRA R940 Keyboard Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the optical drive out.
  12. Toshiba TECRA R940 Keyboard Replacement, Keyboard: Schritt 12, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement, Keyboard: Schritt 12, Bild 2 von 2
    • Move the 4 small tabs, that are placed along the empty battery space, in the direction of where the battery pack would be. They should stay unhooked without having to hold them.
  13. Toshiba TECRA R940 Keyboard Replacement: Schritt 13, Bild 1 von 1
    • Flip the computer over and remove the black strip at the top of the keyboard.
    • If you are having difficulty removing the strip with your hand, try using a spudger to disconnect the strip.
  14. Toshiba TECRA R940 Keyboard Replacement: Schritt 14, Bild 1 von 3 Toshiba TECRA R940 Keyboard Replacement: Schritt 14, Bild 2 von 3 Toshiba TECRA R940 Keyboard Replacement: Schritt 14, Bild 3 von 3
    • Turn the computer over again and press down on the metal notch. This will push the keyboard out of its place.
    • Once you can get a firm grasp on the keyboard make small motions side to side and pull it out of place.
    • The top and right side of the keyboard should be out when you grab it, so to slide it out pull in the direction away from the lower left corner.
    • Make sure not to pull to hard as there is one last connection under the keyboard that could be severed.
  15. Toshiba TECRA R940 Keyboard Replacement: Schritt 15, Bild 1 von 2 Toshiba TECRA R940 Keyboard Replacement: Schritt 15, Bild 2 von 2
    • Push the two tan brackets towards the back of the computer, and safely pull out the connector ribbon.
Abschluss
2 Kommentare
To replace the keyboard you only need to remove one screw (marked KB) on the underside of the laptop. The keyboard can then be easily removed by taking off the plastic bezel by the top row of keys and unclipping from there. Literally a 5 minute job without the need to fully disassemble.
cannysnokia - Antwort
Bravo! You are 100% right
Thanks to your advice, I got rid of unnecessary and unnecessary disassembly work.
Evgeny Johansen -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 2,210
