Einleitung
The optical drive is a relatively simple replacement. It must also be removed to access the keyboard.
Was du brauchst
While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel from the bottom.
Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
Lift the hard drive out of the access panel.
Disconnect the SATA connector from the hard drive by pulling straight out.
Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
Remove two 2.5 mm screws from the side of the optical drive using a Phillips #0 screwdriver.
