Zum Hauptinhalt wechseln
Toshiba Tecra M2 RAM Replacement
Was du brauchst
  1. Toshiba Tecra M2 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so the back compartment is facing up.
    • Place left thumb on the battery lock tab.
    • Place right thumb on the battery release latch.
  2. Toshiba Tecra M2 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Tecra M2 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide both tabs outward at the same time to release battery pack.
  3. Toshiba Tecra M2 RAM Replacement: Schritt 3, Bild 1 von 1
    • Pull out the battery after it has popped out and set aside.
    • The battery and the battery cover are in one piece
  4. Toshiba Tecra M2 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
  5. Toshiba Tecra M2 RAM Replacement: Schritt 5, Bild 1 von 1
    • Turn the device over and open it up to the display and keyboard.
    • Gently lift a corner of the keyboard strip until it pops out of its position.
  6. Toshiba Tecra M2 RAM Replacement: Schritt 6, Bild 1 von 3 Toshiba Tecra M2 RAM Replacement: Schritt 6, Bild 2 von 3 Toshiba Tecra M2 RAM Replacement: Schritt 6, Bild 3 von 3
    • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
  7. Toshiba Tecra M2 RAM Replacement: Schritt 7, Bild 1 von 2 Toshiba Tecra M2 RAM Replacement: Schritt 7, Bild 2 von 2
    • Pop the keyboard up gently and let it rest on top of the touch pad
    • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
  8. Toshiba Tecra M2 RAM Replacement: Schritt 8, Bild 1 von 2 Toshiba Tecra M2 RAM Replacement: Schritt 8, Bild 2 von 2
    • Using a #00 philips head screwdriver, remove the 6mm screw holding the metal plate down.
  9. Toshiba Tecra M2 RAM Replacement: Schritt 9, Bild 1 von 2 Toshiba Tecra M2 RAM Replacement: Schritt 9, Bild 2 von 2
    • Gently remove the keyboard connector film from the motherboard with your fingers by lifting upwards.
    • Set aside the keyboard.
  10. Toshiba Tecra M2 RAM Replacement: Schritt 10, Bild 1 von 3 Toshiba Tecra M2 RAM Replacement: Schritt 10, Bild 2 von 3 Toshiba Tecra M2 RAM Replacement: Schritt 10, Bild 3 von 3
    • Pull back the metal tabs holding down your RAM card at the same time.
    • Grab the module by the sides with two index fingers and pull upwards after it has popped up.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cindy Nguyen
386 Reputation
3 Anleitungen geschrieben
CSU Fullerton, Team 1-6, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 1-6, Bruce Fall 2014
CSUF-BRUCE-F14S1G6
3 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
Awesome. Thanks!
Carl H - Antwort
Wow, so I was about to call BS on this being a weirdly convoluted way to do this, but instead I learned something. In the pictures you can see a panel, right above the Windows Authenticity sticker, with a black "CAUTION" sticker held in by a single screw. Remove this panel and, voila, there's your RAM slot. I kept wondering why the author of this guide was having the reader go to all the trouble of removing the keyboard when obviously you could access this area from this spot on the bottom a whole lot easier.
Well, guess what? Contrary to my initial belief, this is NOT just a more convoluted method of reaching the same slot! So yeah, it's probably worth mentioning that there are actually 2 slots in different locations for anyone else who may be screwing around with this ancient laptop and be as confused as I was for a second there. (I suspect the author just forgot to mention it, since you can see they've removed that back panel stick already in the Step 4 pic.)
Jesse Bettis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 1,226
