Einleitung
If you’re experiencing a hardware failure or just want an upgrade to your device’s performance, this guide will walk you through the steps of replacing your hard drive.
Was du brauchst
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
