Zum Hauptinhalt wechseln
Toshiba Tecra Z50-A Speakers Replacement
Was du brauchst
  1. Toshiba Tecra Z50-A Speakers Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Speakers Replacement: Schritt 2, Bild 1 von 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Speakers Replacement, Battery: Schritt 3, Bild 1 von 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Speakers Replacement: Schritt 4, Bild 1 von 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Speakers Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Speakers Replacement: Schritt 7, Bild 1 von 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Speakers Replacement, Hard Drive: Schritt 8, Bild 1 von 1
    • Lift up on the hard drive.
  9. Toshiba Tecra Z50-A Speakers Replacement: Schritt 9, Bild 1 von 2 Toshiba Tecra Z50-A Speakers Replacement: Schritt 9, Bild 2 von 2
    • Pull out the plug from the hard drive.
  10. Toshiba Tecra Z50-A Speakers Replacement, Speakers: Schritt 10, Bild 1 von 1
    • Lift up on the tape holding the bundled speaker wire down.
  11. Toshiba Tecra Z50-A Speakers Replacement: Schritt 11, Bild 1 von 1
    • Pull the bundled wire out of its socket on the motherboard.
  12. Toshiba Tecra Z50-A Speakers Replacement: Schritt 12, Bild 1 von 3 Toshiba Tecra Z50-A Speakers Replacement: Schritt 12, Bild 2 von 3 Toshiba Tecra Z50-A Speakers Replacement: Schritt 12, Bild 3 von 3
    • Lift up on the left speaker with a spudger.
  13. Toshiba Tecra Z50-A Speakers Replacement: Schritt 13, Bild 1 von 3 Toshiba Tecra Z50-A Speakers Replacement: Schritt 13, Bild 2 von 3 Toshiba Tecra Z50-A Speakers Replacement: Schritt 13, Bild 3 von 3
    • Lift up on the right speaker with a spudger and remove both speakers from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Luis Juen Baez
585 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 266
