Zum Hauptinhalt wechseln
Toshiba Thrive Battery Replacement
  1. Toshiba Thrive Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Battery Replacement: Schritt 2, Bild 1 von 2 Toshiba Thrive Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Battery Replacement: Schritt 3, Bild 1 von 1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Battery Replacement: Schritt 4, Bild 1 von 3 Toshiba Thrive Battery Replacement: Schritt 4, Bild 2 von 3 Toshiba Thrive Battery Replacement: Schritt 4, Bild 3 von 3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Kason
1.120 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 10-1, Brown Fall 2014 Mitglied von USF Tampa, Team 10-1, Brown Fall 2014
USFT-BROWN-F14S10G1
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
You should give links on where we can buy the parts that need to be replaced.
Meggie Guerrer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 2,317
