Einleitung
This guide will show you how to replace your front camera.
Was du brauchst
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Remove back cover by prying away from the Thrive.
The easiest place to pry from is one of the two speakers.
To remove the battery, make sure the lock switch is in the unlocked position.
The battery is unlocked when the switch is slid to the unlocked position.
Slide the battery switch release to the right.
While holding the switch in place, lift up the battery.
Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
All of these screws are identical so don't worry about getting them mixed up.
Start to gently pry the back of the device off, while leaving it loosely in place.
Be careful not to tear or damage the cables when removing the back.
Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
Carefully open the device like a book and lay the two halves beside each other.
Separate the two halves of your Thrive
Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
With a spudger, disconnect the cable connecting the camera to the motherboard.
Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
Lift up the camera from the screen.
