Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Replacing a towel bar needs a guide because sometimes you can find yourself wanting to renovate your bathroom, replace an old rusty towel bar or have a loose towel bar. Instead of hiring someone to perform this very simple task and adding to your expense of home renovations, you can perform this task on your own. Now with this guide anyone with no knowledge of this task can do it themselves.
  1. Measure the length of your current towel bar to make sure that your replacement towel bar is the correct size and will fit onto the same wall brackets.
    • Measure the length of your current towel bar to make sure that your replacement towel bar is the correct size and will fit onto the same wall brackets.
  2. In most cases, you can remove the towel bar by removing the screws underneath the bar holders. In most cases, you can remove the towel bar by removing the screws underneath the bar holders.
    • In most cases, you can remove the towel bar by removing the screws underneath the bar holders.
  3. Remove the towel bar from the wall brackets.
    • Remove the towel bar from the wall brackets.
  4. Place the new towel bar on top of the wall brackets and make sure that the bar is level.
    • Place the new towel bar on top of the wall brackets and make sure that the bar is level.
  5. Insert the screws into the holes beneath each bar holder. Insert the screws into the holes beneath each bar holder.
    • Insert the screws into the holes beneath each bar holder.
  6. After inserting the screws, screw in both sides firmly. Your new towel holder should now be good to use. After inserting the screws, screw in both sides firmly. Your new towel holder should now be good to use.
    • After inserting the screws, screw in both sides firmly. Your new towel holder should now be good to use.
Abschluss
Muhammad Madni
133 Reputation
1 Anleitung geschrieben
York University, Team S3-G55, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G55, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G55
1 Mitglied
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 9
Insgesamt: 99
