Zum Hauptinhalt wechseln
Toy Lightsaber Battery Replacement
Was du brauchst
  1. Toy Lightsaber Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Toy Lightsaber Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Toy Lightsaber Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: Schritt 2, Bild 1 von 3 Toy Lightsaber Battery Replacement: Schritt 2, Bild 2 von 3 Toy Lightsaber Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: Schritt 3, Bild 1 von 3 Toy Lightsaber Battery Replacement: Schritt 3, Bild 2 von 3 Toy Lightsaber Battery Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: Schritt 4, Bild 1 von 3 Toy Lightsaber Battery Replacement: Schritt 4, Bild 2 von 3 Toy Lightsaber Battery Replacement: Schritt 4, Bild 3 von 3
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: Schritt 5, Bild 1 von 3 Toy Lightsaber Battery Replacement: Schritt 5, Bild 2 von 3 Toy Lightsaber Battery Replacement: Schritt 5, Bild 3 von 3
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: Schritt 6, Bild 1 von 3 Toy Lightsaber Battery Replacement: Schritt 6, Bild 2 von 3 Toy Lightsaber Battery Replacement: Schritt 6, Bild 3 von 3
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Zachary Adaes
133 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G1, Saloman Spring 2021 Mitglied von UMass Dartmouth, Team S3-G1, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G1
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 74
Insgesamt: 3,785
