Zum Hauptinhalt wechseln
Toy Windmill Repair
Was du brauchst
  1. Toy Windmill Repair, Toy Windmill Repair: Schritt 1, Bild 1 von 1
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: Schritt 2, Bild 1 von 1
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: Schritt 3, Bild 1 von 2 Toy Windmill Repair: Schritt 3, Bild 2 von 2
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: Schritt 4, Bild 1 von 1
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: Schritt 5, Bild 1 von 1
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: Schritt 6, Bild 1 von 2 Toy Windmill Repair: Schritt 6, Bild 2 von 2
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
Abschluss
To reassemble your device, follow these instructions in order.
Karim Ladha
133 Reputation
1 Anleitung geschrieben
York University, Team S2-G15, Melo-Thaiss Summer 2021 Mitglied von York University, Team S2-G15, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G15
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 320
