Einleitung
This Guide will show how to troubleshoot your car’s charging system safely. I stress safely because even though a car battery’s voltage is only 12.6V it can put out current in excess of 600A (Amperes) enough to melt cables and set them on fire, cause serious burns, weld metal to metal, and, as a bonus on the danger front, a short-circuited car battery could explode! So at every stage of automotive troubleshooting, but especially of the high current capable charging system you never want the possibility of the battery positive being shorted to the chassis,(battery Negative) or another return path.
NOTE: I have listed both alternator variants for GT and GTS as well as 120A fuse which should be good. In troubleshooting, you may find you need none of these parts! The parts are listed so that are easy to identify and find if you do.
NOTE2: Removing the battery will reset all of the emission monitor systems that will take some driving to reset, bear this in mind if you are working close to your car’s inspection.
Check your battery voltage with the engine off by selecting DC Voltage on your multi-meter and putting the red probe on the positive terminal and the black problem on the negative terminal as fully charged battery will show around 12.6V( Volts.) if the Voltage is 10.6V or lower your battery is fully discharged,(flat).
Start the car and repeat the test the voltage should show between 13.5V and 14.5V. If this is the case, the issue could be your battery as it should take charge.
If the voltage is still at 12.6V or less with the engine running the battery is not being charged! It's time to troubleshoot the charging circuit!
Remove the lefthand plastic cover. It is held in place by 4 plastic pins, these have a crosshead and 'should' unscrew enough to be pulled up. In practice, you may have to pry the center pin out.
Now check the alternator is being driven. Check the drive belt is not slipping or broken! If either is true replace the belt and skip ahead to the reassembly stage for how to fit a new drive belt.
Now Turn off the engine, All the power is coming from your battery you do not want to completely drain it!
Disconnect the Battery Terminal connectors. Always Disconnect the Negative (-)Terminal first! You do this so when you disconnect the Positive Terminal (+) if you wrench touches the bodywork you don't short out the battery as the whole of the car's bodywork is connected to battery Negative!
Open the Fuse box and check the 120A charging fuse. My fuse was good you can see the copper link. You can test the fuse with your multi-meter set on Resistance(Ω). Place one probe on each of the fuse retaining screws. It should read 0Ω (Ohms) as shown. (I would expect this fuse to be good.)
With the Battery disconnected. Disconnect the B+ cable from the alternator using a 10mm socket. With your multi-meter set on Resistance(Ω) put one probe through the B+ cable connector and the other on the battery Positive wire you should see close to 0Ω. You have now verified the wiring to the battery.
At this point, it is fairly certain your alternator has failed!
Unclip and remove the wire from a holding point on the side of the Alternator.
Unplug the 3 wire connector from the side of the alternator. If you did not B+ cable to perform the continuity test disconnect it now with a 10mm socket.
Remove the 12mm bolt holding the top of the alternator in place, then remove the long 14mm bolt. You will need patience to racket it out as there is not a lot of room to move your wrench thanks to the A/C piping!
Using a 19mm socket and a long socket wrench, put the socket on the 19mm location on the side of the belt tensioner and push down to compress its piston and slacken the belt, while the belt is slack remove it the the alternator's drive wheel.
I unbolted the cruise control unit, removing three 10mm bolts to give me more room to pull out the old alternator. Also disconnecting the A/C cable will give you more room.
Optional: If you have never replaced the drive belt you may want to inspect it for wear and damage whilst you have the alternator out.
Optional: At this point, you may want to put your battery on charge in a well ventilated dry area, my new battery was fully discharged after one short night trip and a couple of starts with a dead alternator. Leaving a car battery discharged for any period of time can shorten its life.
Note: I checked my failed alternator and found the rectifier had failed. But for the price of used alternators, it made more sense to replace the whole unit!
Insert the replacement Alternator into place. You may need to tap (not hit) with a hammer or mallet until the holes align. Screw the bottom bolt in as far as you can by hand as you have little ratcheting space. Tighten up both bolts.
Attach the B+ and Tighten the 10mm retaining bolt. Plugin the Three wire connector. Clip the wiring harness onto the mounting point.
Important: Using a 19mm socket and a long wrench, compress the tensioner and place the Belt over the Alternators pully wheel. Release and check the belt is fully on all pully wheels, use a flashlight if necessary. Failing to do so can shred your belt. Check Service manual PDF 2, page 313 if you need more info regarding belt fitment.
Reinstall the Cruise Control unit if you removed it. Plugin the A/C cable if you unplugged it.
Reinstall the battery If you removed it. Connect the Positive (+) terminal first then the Negative (-) terminal.
Start your car and with the engine running use your multimeter on DC Voltage range to check you and above 14V at your battery terminals.
If everything is good, turn off your engine. Reinstall your plastic cover.
