Einleitung
If your brake light has certain issues that stop the light from working such as a burned-out bulb, a bad brake light switch, or blown fuse, this guide will provide you thorough instructions on how to replace new brake lights for a Toyota Corolla year 2018.
Was du brauchst
Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
The rear turn signal bulb is located at the top and has a grey cap.
The brake light is located at the bottom and has an orange cap.
Turn the brake light counterclockwise and pull the old light straight out of the socket.
Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
