Einleitung
Use this guide to locate the fuse box and replace damaged fuses of Toyota Premio 2015. A blown wire can regularly be the guilty party for what is by all accounts bigger electrical issues. Figure out how to check your breakers and supplant any that need it.
Was du brauchst
Pull the auxiliary latch lever and then lift the hood above.
To hold the hood open, lift and insert the supporting rod into the slot.
Gently push the tab in and lift the fuse box lid off.
Now, the fuse panel with various fuses of different amperage ratings and colours are shown.
Use the fuse remover tool to take the fuse out of the box.
Check the fuse to determine whether the fuse is broken or not. If the internal wires inside the fuse is not attached, it must be changed. The picture shows three types of fuse:
Normal fuse
Broken fuse
Replace the blown fuse with a new replacement fuse of an appropriate amperage rating. The amperage rating can be found on the fuse box lid.
After you've replaced the fuse, start the car and check to see whether whatever the fuse was responsible for is now operational, such as your interior lighting.
After you've double-checked that everything is working properly, replace the fuse box lid.
Hope this guide has helped you replace any damaged fuse on your car. Please do routinely check your fuse box every 6 months.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
