Zum Hauptinhalt wechseln
Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement
Was du brauchst
  1. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: Schritt 1, Bild 1 von 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: Schritt 1, Bild 2 von 2
    • Remove the Torx-head screws (23.2mm) on the inside panel of the tailgate, using the torx T25 screwdriver.
  2. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 2, Bild 1 von 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 2, Bild 2 von 2
    • Pull off the panel and then pull cables inward, causing tailgate to release and go down.
  3. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 3, Bild 1 von 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 3, Bild 2 von 2
    • Remove rubber pieces from cable and pull cable from insert.
  4. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 4, Bild 1 von 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 4, Bild 2 von 2
    • Use your 5/16th-in. wrench to turn bolt counter clockwise and remove the bolts (18.5mm).
  5. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 5, Bild 1 von 2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 5, Bild 2 von 2
    • Push in black clip to let handle fall out.
  6. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 6, Bild 1 von 1
    • Put new tailgate handle back in.
  7. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 7, Bild 1 von 1
    • Hand twist in bolts; then tighten with wrench.
  8. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 8, Bild 1 von 1
    • Insert cable back into socket and press rubber lock onto cable.
  9. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: Schritt 9, Bild 1 von 1
    • Put panel back into place and screw in using your torx -T25 screwdriver.
Abschluss
This Device is a medium hardness fix but, with hard-work it can be achieved in only about 30 minutes
Brandon Gibson
169 Reputation
1 Anleitung geschrieben
2 Kommentare
You skipped the problematic part about changing the lock.
Declan Haptism - Antwort
I’m about to replace my handle.. I also need the 4 white clips that help align the latch rods. Mine were old brittle and all broken. Any chance you have a part number for those small clips?
Ryan Rodriguez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 181
Insgesamt: 9,958
