Zum Hauptinhalt wechseln
Transforming High-Rise Pants into Low-Rise Style by Hand
Was du brauchst
    1. Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 1, Bild 1 von 2 Transforming High-Rise Pants into Low-Rise Style by Hand, Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 1, Bild 2 von 2
      • Begin by turning pants inside out and laying flat.
      Frag FixBot
      Kommentar hinzufügen
    2. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 2, Bild 1 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 2, Bild 2 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 2, Bild 3 von 3
      • Line up the seams to match on both sides.
      • Mark where you would like the new bottom of your pants to sit.
      • Using a straight edge, mark a line going down from the initial mark down to the leg of the pants.
      Frag FixBot
    3. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 3, Bild 1 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 3, Bild 2 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 3, Bild 3 von 3
      • After the guide lines have been drawn out, cut off the fabric marked off leaving roughly 1cm for seam allowance.
      Frag FixBot
    4. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 4, Bild 1 von 2 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 4, Bild 2 von 2
      • Line up the fabric on both sides and pin together keeping the fabric in line.
      Frag FixBot
    5. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 5, Bild 1 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 5, Bild 2 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 5, Bild 3 von 3
      • Thread your needle with a thread close to the color of the pants you are altering.
      • Tie the ends of the thread into a knot large enough to not go through the fabric being sewn.
      Frag FixBot
    6. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 6, Bild 1 von 2 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 6, Bild 2 von 2
      • Insert the needle into the bottom of the marked line to begin your stitch.
      Frag FixBot
    7. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 7, Bild 1 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 7, Bild 2 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 7, Bild 3 von 3
      • Pull thread through the fabric and reinsert leaving about 1mm in between.
      • Insert the needle on the back side of the fabric about 1mm away from the previous stitch.
      • Insert the needle back into the initial stitch to create a backstitch.
      Frag FixBot
    8. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 8, Bild 1 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 8, Bild 2 von 3 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 8, Bild 3 von 3
      • Continue backstitching all around the marked line.
      • Tie off the thread once you reach the end by tying a knot into the final stitch.
      Frag FixBot
    9. Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 9, Bild 1 von 2 Transforming High-Rise Pants into Low-Rise Style by Hand: Schritt 9, Bild 2 von 2
      • Flip pants right side out and enjoy your new low-rise pants!
      Frag FixBot
Ziellinie
Addison Cavenee
169 Reputation
1 Anleitung geschrieben
Rose State College, Team 2-4, Kirkman Spring 2025 Mitglied von Rose State College, Team 2-4, Kirkman Spring 2025
ROSE-KIRKMAN-S25S2G4
1 Mitglied
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 33
Letzte 30 Tage: 92
Insgesamt: 832
