Zum Hauptinhalt wechseln
Trek 4300 Bicycle Kickstand Replacement
Was du brauchst
  1. Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: Schritt 1, Bild 1 von 2 Trek 4300 Bicycle Kickstand Replacement, Loosen Bracket: Schritt 1, Bild 2 von 2
    • Flip the bike over so it is balanced and resting on the handlebar and the bike seat.
    • Using a socket screwdriver with a hex adapter, loosen the bolt that is holding the kickstand and bracket in place.
    • This may require a moderate amount of strength. Make sure you have the proper hex adapter as to not strip the bolt.
  2. Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: Schritt 2, Bild 1 von 2 Trek 4300 Bicycle Kickstand Replacement, Remove the kickstand: Schritt 2, Bild 2 von 2
    • Once the bolt is loose, unscrew it the rest of the way by hand.
    • Remove the bolt. There should now be three separate pieces: the bolt, the bracket, and the kickstand.
    • Make sure to note the position of the bracket before you remove the bolt completely
Abschluss
To replace the new kickstand, follow these instructions in reverse order.
Emily OConnor
500 Reputation
4 Anleitungen geschrieben
Clemson, Team 3-2, Benson Fall 2014 Mitglied von Clemson, Team 3-2, Benson Fall 2014
CLEM-BENSON-F14S3G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 20
Insgesamt: 2,824
