Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Facing your bike, straddle your front wheel between your knees. Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
    • Facing your bike, straddle your front wheel between your knees.
    • Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
    • Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
  2. With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand. The brake will now be open wide enough to permit removal of the wheel.
    • With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand.
    • The brake will now be open wide enough to permit removal of the wheel.
  3. Find the quick release lever on the outside of the bike's fork on the right hand side. Turn the level counter clockwise loosening the lever until it comes off. Find the quick release lever on the outside of the bike's fork on the right hand side. Turn the level counter clockwise loosening the lever until it comes off.
    • Find the quick release lever on the outside of the bike's fork on the right hand side. Turn the level counter clockwise loosening the lever until it comes off.
  4. After the quick release lever is removed, the wheel can be separated from the front fork.
    • After the quick release lever is removed, the wheel can be separated from the front fork.
    • In reassembling the wheel to the bike, perform the steps in reverse order.
    • With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
    • Squeeze the brake calipers together and return the cable noodle back into the holder.
    • Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
  5. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  6. Locate the tire pressure valve.
    • Locate the tire pressure valve.
  7. First, you must release the air.
    • First, you must release the air.
    • To release the air from the tire, press the center spoke in the middle of the air pressure valve.
    • Release air until no more air is being released.
  8. Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel
    • Use a sturdy, long object, such as a screwdriver or the back of a spoon, to wedge in between the tire and the wheel
  9. Now you may separate the tire from the wheel. Be careful pulling the tire from the wheel around the air pressure valve. Be careful pulling the tire from the wheel around the air pressure valve.
    • Now you may separate the tire from the wheel.
    • Be careful pulling the tire from the wheel around the air pressure valve.
  10. To remove the tube, all you need to do is pull the tube from the inner lining of the tire. To remove the tube, all you need to do is pull the tube from the inner lining of the tire.
    • To remove the tube, all you need to do is pull the tube from the inner lining of the tire.
  11. Make sure you have removed the tires as shown in the prerequisite guides. Slowly peel back the layer of rubber that  covers the 32 screws on the tire .
    • Make sure you have removed the tires as shown in the prerequisite guides.
    • Slowly peel back the layer of rubber that covers the 32 screws on the tire .
  12. You will need a flathead screwdriver You will need to alternate between steps #2 and #3 because the spokes have to be removed one  at a time. Remove the screw using the flathead.
    • You will need a flathead screwdriver
    • You will need to alternate between steps #2 and #3 because the spokes have to be removed one at a time.
    • Remove the screw using the flathead.
    • All screws will be the same size.
    • Only remove the screws of the spokes you are replacing.
  13. Once a screw is removed gently remove the spoke from the rim of the tire  if it did not fall out. Maneuver the spoke so that it is perpendicular then slide the spoke out. Maneuver the spoke so that it is perpendicular then slide the spoke out.
    • Once a screw is removed gently remove the spoke from the rim of the tire if it did not fall out.
    • Maneuver the spoke so that it is perpendicular then slide the spoke out.
  14. Insert the new spoke into the missing hole.
    • Insert the new spoke into the missing hole.
    • If you are replacing multiple spoke , you will need to alternate between steps #4, and #5 . The spokes must be replaced one at a time.
  15. Use the flat head screw driver to insert a  screw  to stop the spoke from falling out.
    • Use the flat head screw driver to insert a screw to stop the spoke from falling out.
Abschluss
To reassemble your wheel after following steps #4, and #5 simply reattach the rubber tire.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kaveh Karimiyanha
807 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 1-1, Propen Fall 2012 Mitglied von Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 5
Insgesamt: 1,977
