Zum Hauptinhalt wechseln
Trek Neko Bike Brake Pad Replacement
Was du brauchst
  1. Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: Schritt 1, Bild 1 von 2 Trek Neko Bike Brake Pad Replacement, Bike Brake Pad: Schritt 1, Bild 2 von 2
    • Squeeze the two brake arms together.
    • Angle the brake noodle down.
    • Push the quick release down to release the brake noodle.
  2. Trek Neko Bike Brake Pad Replacement: Schritt 2, Bild 1 von 1
    • Flip the bike over so that the seat is on the ground.
  3. Trek Neko Bike Brake Pad Replacement: Schritt 3, Bild 1 von 3 Trek Neko Bike Brake Pad Replacement: Schritt 3, Bild 2 von 3 Trek Neko Bike Brake Pad Replacement: Schritt 3, Bild 3 von 3
    • Open the quick release lever on the bike wheel.
    • Rotate the lever in a counter clockwise direction to loosen the wheel.
    • Remove the wheel from the bike frame.
  4. Trek Neko Bike Brake Pad Replacement: Schritt 4, Bild 1 von 2 Trek Neko Bike Brake Pad Replacement: Schritt 4, Bild 2 von 2
    • Loosen the locking bolt on the brake pad with a 5 mm Allen wrench.
    • Remove the locking bolt, washers, and brake pad from the brake pad housing.
  5. Trek Neko Bike Brake Pad Replacement: Schritt 5, Bild 1 von 2 Trek Neko Bike Brake Pad Replacement: Schritt 5, Bild 2 von 2
    • Insert the new brake pad.
    • Insert the washers.
    • Insert the locking bolt.
  6. Trek Neko Bike Brake Pad Replacement: Schritt 6, Bild 1 von 2 Trek Neko Bike Brake Pad Replacement: Schritt 6, Bild 2 von 2
    • Tighten the brake pad locking bolt bolt clockwise until it is finger tight.
    • Tighten the bolt with a 5 mm Allen wrench.
  7. Trek Neko Bike Brake Pad Replacement: Schritt 7, Bild 1 von 3 Trek Neko Bike Brake Pad Replacement: Schritt 7, Bild 2 von 3 Trek Neko Bike Brake Pad Replacement: Schritt 7, Bild 3 von 3
    • Reinsert the wheel.
    • Tighten the bolt on the wheel until it is finger tight.
    • Center the wheel in the frame.
    • Close the quick release lever to secure the wheel.
  8. Trek Neko Bike Brake Pad Replacement: Schritt 8, Bild 1 von 2 Trek Neko Bike Brake Pad Replacement: Schritt 8, Bild 2 von 2
    • Place the bike right side up.
  9. Trek Neko Bike Brake Pad Replacement: Schritt 9, Bild 1 von 3 Trek Neko Bike Brake Pad Replacement: Schritt 9, Bild 2 von 3 Trek Neko Bike Brake Pad Replacement: Schritt 9, Bild 3 von 3
    • Insert the brake noodle into the quick release lever.
    • Angle the quick release lever upwards so that the brake noodle clicks into place.
  10. Trek Neko Bike Brake Pad Replacement: Schritt 10, Bild 1 von 2 Trek Neko Bike Brake Pad Replacement: Schritt 10, Bild 2 von 2
    • Squeeze the brakes to check proper fitment.
    • Tighten or loosen the quick release bolt on the brake arms to adjust based on preference.
Abschluss
With properly installed brake pads, you can now safely ride your bike!
2 weitere Personen haben diese Anleitung absolviert.
Camille Nikaido
181 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-9, Andersen Winter 2023 Mitglied von UC Davis, Team 1-9, Andersen Winter 2023
UCD-ANDERSEN-W23S1G9
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 51
Insgesamt: 444
