Einleitung
Follow the guide to replace the glass or other parts of the device once it's open
With a thin opening tool remove the back cover prying between screen and cover on all the device edges.
Be careful not to damage the speaker screwed to the back cover with two screws.
Unscrew the screws and remove the speaker from the back cover.
With the help of a hairdryer or any heat source, heat the corners of the glass and with a thin tool remove the adhesive and subsequently the glass
Lift up the protective film of the touchscreen connector.
Push the two black clips to disconnect the ribbon cable connector.
To reassemble the device, follow these instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
