Zum Hauptinhalt wechseln
Triace A310 Chain Replacement
Was du brauchst
  1. Triace A310 Chain Replacement, Tire: Schritt 1, Bild 1 von 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Chain Replacement: Schritt 2, Bild 1 von 2 Triace A310 Chain Replacement: Schritt 2, Bild 2 von 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Chain Replacement: Schritt 3, Bild 1 von 2 Triace A310 Chain Replacement: Schritt 3, Bild 2 von 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Chain Replacement, Chain: Schritt 4, Bild 1 von 3 Triace A310 Chain Replacement, Chain: Schritt 4, Bild 2 von 3 Triace A310 Chain Replacement, Chain: Schritt 4, Bild 3 von 3
    • Locate the master link along the chain.
    • Note: If the master link matches the one pictured in this step continue with the instructions, if not skip to the next step.
    • With pliers squeeze the two pins together so that the chain comes apart.
  5. Triace A310 Chain Replacement: Schritt 5, Bild 1 von 3 Triace A310 Chain Replacement: Schritt 5, Bild 2 von 3 Triace A310 Chain Replacement: Schritt 5, Bild 3 von 3
    • Note: This step is only for chains with a master link clip.
    • With a plier press the two pins together and remove the clip.
    • Once the clip is removed the chain should easily come apart.
  6. Triace A310 Chain Replacement: Schritt 6, Bild 1 von 1
    • Once the chain is separated, remove it from the bike by pulling one end.
  7. Triace A310 Chain Replacement: Schritt 7, Bild 1 von 3 Triace A310 Chain Replacement: Schritt 7, Bild 2 von 3 Triace A310 Chain Replacement: Schritt 7, Bild 3 von 3
    • With the new chain, place it on the current gear that your bike is in.
    • Note: If you don't know which gear your bike is in place the chain on one of the middle gears.
    • Thread one end of the chain through the derailleur from top to bottom so it is in the shape of a 'S'.
    • Next place the chain on the back gears, making sure that it is threaded through the guide.
  8. Triace A310 Chain Replacement: Schritt 8, Bild 1 von 3 Triace A310 Chain Replacement: Schritt 8, Bild 2 von 3 Triace A310 Chain Replacement: Schritt 8, Bild 3 von 3
    • To reassemble the chain bring both ends of the chain together so that the pins on each one lineup.
    • Grip the chain on both sides of the master link and pull.
  9. Triace A310 Chain Replacement: Schritt 9, Bild 1 von 3 Triace A310 Chain Replacement: Schritt 9, Bild 2 von 3 Triace A310 Chain Replacement: Schritt 9, Bild 3 von 3
    • If your chain does have a master link clip replace the link around the two pins.
    • Use a plier to slide the clip back into place.
Abschluss
Once your chain is back together, you are ready to once again, hit the trails.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 1-37, Maness Winter 2014 Mitglied von Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 704
