Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In order to have a safer biking experience, make sure your disk brake is properly replaced.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Begin loosening the tire by turning the quick release handle.
    • Begin loosening the tire by turning the quick release handle.
  2. Gripping the rear derailleur, pull the arm back, away from the front of the bike. Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. There should be enough slack, in the chain, at this point to remove the tire from the bike. Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  5. Place the tire  flat on the ground making sure the disk is facing you.
    • Place the tire flat on the ground making sure the disk is facing you.
  6. Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws. Make sure to keep track of all of the removed pieces. Make sure to keep track of all of the removed pieces.
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  7. After all of the screws have been removed, take the disk and pull it away from the tire. After all of the screws have been removed, take the disk and pull it away from the tire.
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Abschluss
Daniel
222 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 1-37, Maness Winter 2014 Mitglied von Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 390
