Einleitung
This guide will help you replace the batteries of your Tribit X Sound Go speaker.
Note: There might be a swollen battery or battery acid, please use caution.
Was du brauchst
Insert a spudger in the seam between the front speaker grill and chassis.
Pry around the perimeter until the front grill releases.
Remove the front grill.
Remove the 14 Phillips screws around the perimeter of the speaker.
Lift off the speaker housing.
Disconnect the white speaker connections by gently pulling up with tweezers.
Find the battery cover.
Use a screwdriver to unscrew the sides of the covering.
Disconnect the batteries by pulling the battery connectors directly out of their motherboard ports.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Same here. What is the replacement battery number?
