Zum Hauptinhalt wechseln
Tribit XSound Go TS-BTS20 Passive Radiator Replacement
Was du brauchst
  1. Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: Schritt 1, Bild 1 von 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement, Passive Radiator: Schritt 1, Bild 2 von 2
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all the screws with the Phillips screwdriver, on the opened panel.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: Schritt 3, Bild 1 von 2 Tribit XSound Go TS-BTS20 Passive Radiator Replacement: Schritt 3, Bild 2 von 2
    • Hold the frame which has the passive radiator in the middle.
  4. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to push the damaged passive radiator off the frame
  5. Tribit XSound Go TS-BTS20 Passive Radiator Replacement: Schritt 5, Bild 1 von 1
    • Insert the new passive radiator into the frame.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 47
