Einleitung
Removing the camera should not be difficult task, but you should use caution and make sure not to interfere with any of the cables and such in the way of the camera.
Was du brauchst
Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
Disconnect the camera from the motherboard on the topside and pull the camera strip out.
Fast fertig!
Abschluss
