Zum Hauptinhalt wechseln
Trio AXS 3G Screen Replacement
Was du brauchst
  1. Trio AXS 3G Screen Replacement, Back Case: Schritt 1, Bild 1 von 1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Screen Replacement: Schritt 2, Bild 1 von 2 Trio AXS 3G Screen Replacement: Schritt 2, Bild 2 von 2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Screen Replacement: Schritt 3, Bild 1 von 1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Screen Replacement, Screen: Schritt 4, Bild 1 von 1
    • The motherboard and battery will have to be removed to expose the metal panel underneath.
  5. Trio AXS 3G Screen Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Use the plastic card to pry the battery away from the device.
    • The battery is attached to the tablet by glue.
  6. Trio AXS 3G Screen Replacement: Schritt 6, Bild 1 von 1
    • Peel off the battery from the device and set aside.
    • The battery is connected to the motherboard by two wires. Be careful not to sever the connection.
  7. Trio AXS 3G Screen Replacement: Schritt 7, Bild 1 von 1
    • Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
  8. Trio AXS 3G Screen Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the silver tape that attaches the motherboard to the metal panel.
  9. Trio AXS 3G Screen Replacement: Schritt 9, Bild 1 von 1
    • Disconnect the ribbon from the bottom portion of the motherboard.
  10. Trio AXS 3G Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard and set aside.
  11. Trio AXS 3G Screen Replacement: Schritt 11, Bild 1 von 1
    • The smaller portion of the motherboard is located at the bottom with the speaker.
    • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
  12. Trio AXS 3G Screen Replacement: Schritt 12, Bild 1 von 2 Trio AXS 3G Screen Replacement: Schritt 12, Bild 2 von 2
    • Located towards the bottom, carefully remove the yellow film.
  13. Trio AXS 3G Screen Replacement: Schritt 13, Bild 1 von 1
    • Gently disconnect the small ribbon found underneath the film.
  14. Trio AXS 3G Screen Replacement: Schritt 14, Bild 1 von 1
    • There is another connection found underneath this portion of the motherboard.
    • Lifting up the motherboard, disconnect the second ribbon found underneath.
  15. Trio AXS 3G Screen Replacement: Schritt 15, Bild 1 von 1
    • Unscrew the two 4 mm #000 screws.
  16. Trio AXS 3G Screen Replacement: Schritt 16, Bild 1 von 1
    • Remove the speaker and bottom portion of the motherboard.
  17. Trio AXS 3G Screen Replacement: Schritt 17, Bild 1 von 1
    • At this stage, almost all inside components should be removed (as shown).
    • Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
  18. Trio AXS 3G Screen Replacement: Schritt 18, Bild 1 von 3 Trio AXS 3G Screen Replacement: Schritt 18, Bild 2 von 3 Trio AXS 3G Screen Replacement: Schritt 18, Bild 3 von 3
    • Use the plastic card to separate the metal panel from the screen component.
  19. Trio AXS 3G Screen Replacement: Schritt 19, Bild 1 von 1
    • Separate memory card from screen.
  20. Trio AXS 3G Screen Replacement: Schritt 20, Bild 1 von 2 Trio AXS 3G Screen Replacement: Schritt 20, Bild 2 von 2
    • Use the plastic card to separate screen component from front panel.
  21. Trio AXS 3G Screen Replacement: Schritt 21, Bild 1 von 1
    • Use the plastic card to separate the glass from the front panel.
    • Once the glass is removed, the new glass can be fitted to the front panel.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 939
