Zum Hauptinhalt wechseln
Trio STEALTH-9 Back Cover Replacement
Was du brauchst
  1. Trio STEALTH-9 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
Abschluss
To reassemble your device, follow these instructions in reverse order with your replacement cover!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Mei Liang
228 Reputation
2 Anleitungen geschrieben
Clemson, Team 15-5, Shirley Winter 2015 Mitglied von Clemson, Team 15-5, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G5
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Tengo.una y costo tiene el.displey
eliehtmaria - Antwort
Deseo.saber el.c
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,163
