Zum Hauptinhalt wechseln
Trio STEALTH-9 Camera Replacement
Was du brauchst
  1. Trio STEALTH-9 Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two Phillips #00 screws on the side of the tablet.
  2. Trio STEALTH-9 Camera Replacement: Schritt 2, Bild 1 von 1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
  3. Trio STEALTH-9 Camera Replacement: Schritt 3, Bild 1 von 1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
  4. Trio STEALTH-9 Camera Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
  5. Trio STEALTH-9 Camera Replacement, Camera: Schritt 5, Bild 1 von 2 Trio STEALTH-9 Camera Replacement, Camera: Schritt 5, Bild 2 von 2
    • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
  6. Trio STEALTH-9 Camera Replacement: Schritt 6, Bild 1 von 2 Trio STEALTH-9 Camera Replacement: Schritt 6, Bild 2 von 2
    • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
  7. Trio STEALTH-9 Camera Replacement: Schritt 7, Bild 1 von 2 Trio STEALTH-9 Camera Replacement: Schritt 7, Bild 2 von 2
    • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
    • Remove the camera from the frame and replace as needed.
Abschluss
[deleted]
415 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 141
