Einleitung
This Motherboard you will be fixing/replacing will contain sensitive electronic parts, so be very careful!
Was du brauchst
Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
Prepare your Soldering Iron and Removal Tools.
Contact the iron with each of the battery leads, and pull the lead away from the board.
Remove any excess solder as needed.
To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
Apply heat and solder to each lead individually.
Remove any excess solder if flooding occurs.
Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
Remove the camera from the frame and replace as needed.
Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
Use a pair of Tweezers to carefully pull the side buttons away from the frame.
Use the same Tweezers to carefully pull the microphone away from the front of the frame.
Use your fingernails or a plastic opening tool to remove any remaining ribbon cables from the Motherboard.
With the cables removed, lift the Motherboard off of the frame.
Repair or replace the Motherboard as needed.
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
