Was du brauchst
Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
Carefully peel the tape holding down the wires connected to the speaker.
While holding the mother board down, slowly remove the battery from tape on the back of the screen.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
