Zum Hauptinhalt wechseln
Trio Stealth G2 Hype Motherboard Replacement
Was du brauchst
  1. Trio Stealth G2 Hype Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 Trio Stealth G2 Hype Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Motherboard Replacement: Schritt 3, Bild 1 von 3 Trio Stealth G2 Hype Motherboard Replacement: Schritt 3, Bild 2 von 3 Trio Stealth G2 Hype Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Motherboard Replacement, Speakers: Schritt 4, Bild 1 von 2 Trio Stealth G2 Hype Motherboard Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Motherboard Replacement: Schritt 5, Bild 1 von 1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
  6. Trio Stealth G2 Hype Motherboard Replacement, Battery: Schritt 6, Bild 1 von 2 Trio Stealth G2 Hype Motherboard Replacement, Battery: Schritt 6, Bild 2 von 2
    • While holding the mother board down, slowly remove the battery from tape on the back of the screen.
    • Make sure to keep all wires attached for now.
  7. Trio Stealth G2 Hype Motherboard Replacement: Schritt 7, Bild 1 von 1
    • In order to replace the battery once the wires are removed, you will need to solder the wires of the new battery onto the motherboard.
    • The red wire must be soldered to the "+" terminal while the black is soldered to the "-" terminal.
    • Pull the wires off the motherboard.
  8. Trio Stealth G2 Hype Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 3 Trio Stealth G2 Hype Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 3 Trio Stealth G2 Hype Motherboard Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Peel the black tape located on the left side of the motherboard.
    • Peel the orange tape holding down the wire coming from the bottom left side of the motherboard.
  9. Trio Stealth G2 Hype Motherboard Replacement: Schritt 9, Bild 1 von 3 Trio Stealth G2 Hype Motherboard Replacement: Schritt 9, Bild 2 von 3 Trio Stealth G2 Hype Motherboard Replacement: Schritt 9, Bild 3 von 3
    • The screws to remove the motherboard are located on the top hand side towards the charging port.
    • To reveal the screws, peel of the thin yellow film that covers the whole motherboard just until the screws are accessible.
    • Remove the three 1.2mm Phillips #1 screws using the screwdriver in your 26 Bit Driver Kit.
  10. Trio Stealth G2 Hype Motherboard Replacement: Schritt 10, Bild 1 von 2 Trio Stealth G2 Hype Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the orange tape holding the wires to the back of the screen.
    • Simply lift the motherboard of the back of the screen.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 579
