Zum Hauptinhalt wechseln
Trio Stealth G2 Hype Speakers Replacement
Was du brauchst
  1. Trio Stealth G2 Hype Speakers Replacement, Back Panel: Schritt 1, Bild 1 von 2 Trio Stealth G2 Hype Speakers Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Speakers Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Speakers Replacement: Schritt 3, Bild 1 von 3 Trio Stealth G2 Hype Speakers Replacement: Schritt 3, Bild 2 von 3 Trio Stealth G2 Hype Speakers Replacement: Schritt 3, Bild 3 von 3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
  4. Trio Stealth G2 Hype Speakers Replacement, Speakers: Schritt 4, Bild 1 von 2 Trio Stealth G2 Hype Speakers Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Carefully peel the tape holding down the wires connected to the speaker.
  5. Trio Stealth G2 Hype Speakers Replacement: Schritt 5, Bild 1 von 1
    • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
    • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
    • Pull the speaker and wires from the motherboard.
Abschluss
USF Tampa, Team 4-4, Brown Winter 2015 Mitglied von USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 225
